Small world I'm non-adjoining next door to 195. I understand what you say about their combi but only a couple of weeks ago they did not realise that raw sewage was leaking from the drain on the drive outside their house ☹. With all the advice given above (thanks to all) it sounds like I need to get the pressure/flow tested at the mains outside to see if its worth upgrading the mains supply pipe to the house? Is this something the water company will do or do I need to call a specialist company?
Whoever tests the mains, I'll wait till the holidays are over as the water pressure/flow always drops away when everyone's back at work/school. If I understand correctly, whichever way I go with the heating and hot water the mains water is the first thing to check and/or upgrade?
Well after a few weeks waiting and a lot of phone calls to Affinity Water, on the second visit from one of their engineers I got the mains pressure/flow readings from the mains in the street outside. Pressure is 2.5 and flow rate is 35 lpm. Inside the house the its just below 2.5 bar but only 15 lpm.
Does this mean that it's worth upgrading/replacing my supply pipe from the mains outside into the house in order to have either an unvented cylinder type system or even a high flow combi? Thanks chaps (and chapesses .
Update...new 22mm mains pipe fitted from edge of our property into house, flow is now noticeably better . I'm now awaiting a quote for a new boiler and unvented cylinder solution, which I hope will allow 2 showers to run at the same time. Many thanks to dilalio of this forum. I'll keep popping updates on as it may help other users. I also want a water softener, Monarch seem to do a halfway reasonable high-flow version for around £500, anyone have any experience with either Monarch or other softeners combined with an unvented setup?
