Hi RF,
I've worn contacts on and off for a several years, mainly Boots own. About a month ago I did the Specsavers free trial as the Boots ones are quite expensive and not great. I found the Specsavers daily disposables very good in comparison and good value (they do 3 types, I was using the most comfortable ones with silicon to prevent drying out).
When I went back for the check up, he re-tested my vision and slightly altered the prescription, you might find the same. CLs won't be as good as Specs, but should be very close. He are my tips.
1. Remember to blink!
sounds stupid but helps lubricate the lens
2. Learn to put them in the right way around, they have a habit of turning inside out.
3. If you do wear them in the shower/pool, they will wash out in direct water
4. Don't try and take them out twice! usually happens when you've had a few and can't remember taking them out, you'll only do it the once mind as tugging on your eyeball isn't pleasant
Did you know that in Spain it is illegal to drive a car without having a spare pair of specs? Assume it is the same for Contact Lenses.. Good luck
Tnarg
