vertical could be interesting
big-all said:dont forget you will need a foundation or base
if you have a base youll need another 9m strait run for a skirting to cover the woodwork underneath although 20mm will be above floor to cover the 20mm shortfall 990 +990=1980
Hightowermark said:Thanks again,
Yes havent taken out the Window but as you said waste, the door eill be made out of the same thing aswell.
What drop do you need to make the slope for the pent would a 6" drop be okay?
And i asume you lay the Shiplap lengh ways?
Cheers V Helpful
Hightowermark said:Also what pins/screws would you use to attach the Shiplap as havent seen it before?
Depend how fussy you are about appearance, I use screws from the inside using small batten fixed to the upright stud so no fixing show on the outside. I think also loglap look better than shiplap, doesn't look too flat but your choice though.Hightowermark said:Also what pins/screws would you use to attach the Shiplap as havent seen it before?
