It may be possible (just) if for example the floor is higher than the ground. Definitely needs careful working out, with accurate measurements and drawings.It isn't going to work is it. If the manhole is only 14" deep and it really is 33metres, you need ~40cm fall for 1:80 - it'll be out the ground by the end.
Also 1 in 80 is the limit. You shouldn't go beyond this to stretch it out, or it's likely you'll get blockages.
