Greetings all
Trying to replace the flow control washer on an Aqualisa 430 mixer valve.
http://www.aqualisa.co.uk/80256D500...52580256D63003BC2D3§ion=customer_services
Problem 1: Can't get the shaft out so there's only a tiny amount of clearance between it and the surrounding tube.
Problem 2: Despite this, just managed to slip a normal O ring (from Plumb Center) into the seat. But the ring isn't fat enough to stop the flow.
Anyone come across this before? Can the shaft be removed? I can't see a way of doing it without risking breaking the whole thing. And are fatter rings available?
Looking at the blow-up diagram (link above), the washer is not listed as a separate item. Has our disposable society reached the point where you have to throw away a hundred quid's worth of ironmongery for the sake of a penny washer?
Paul
Paul
