Hi all
We have 3 North facing arched windows in our house all with leaded detail. Two of these are on the ground floor and one is up on the first floor.
We always have issues with condensation during the winter months and I'm trying to do some work to reduce/remove this if possible this year. The condensation is pretty bad and we end up with pools of water each morning on the wooden frame.
I've tried the old silica gel in the window cill and that was ineffective.
I also have fitted a acrylic sheet cut to fit the arch on the inside of each window - with a gap of about 50mm between this and the glass but not sure if that is helping or making the problem worse. It seems to keep the cold out even though there are gaps around the edges so it's useful for this reason.
I'm not sure if there are leaks in the windows themselves (e.g. cases where putty has fallen out or cracks in the frame) - will have a look tomorrow if possible.
Any tips on what I could do to reduce/resolve the condensation issue?
Help appreciated!
Help appreciated!
