In none of your examples are you actually removing the water vapour that is causing the condensation. Water vapour in your home is created by very simple things.....Breathing, cooking, baths, showers etc. If water vapour is trapped in your house it WILL condensate on any Cold point. The only way of getting water vapour out of your property is to allow ventilation, usually by opening a window, or you could fit an extractor fan that are widely available to use in Double Glazing.
You know what, I actually understand that point, because that's precisely the point I'm trying to make: you cannot actually get rid of water vapour in the air, because it is a natural part of the environment. Well, you can get rid of it, with condensers, etc, but you can't also live in the same space (because you being there and breathing will put water vapour back into the air).
But, the science is (wow, look it up, see if I am not lying) that water vapour in the air, or humidity, only condenses upon cooling (otherwise it would not be "water vapour" it would be "water", or as we are currently concerned, condensation). So, what you need to do in order to prevent condensation is to stop the air cooling or to warm the surfaces (this is effectively what you when you blow air over glass to clear it of misting). This is why radiators are generally placed under windows.
The neat trick of humidity is that the air has a higher capacity for water vapour the warmer that air is (ie when it cools it condenses - that's how condensers work). It follows from this that, if you do not have condensation all over your property, you only have localised condensation, then you need to eliminate the cool spots that are causing the condensation.
Now, you don't know the inside of my flat, and I do, so I can tell you, with some confidence, that the only cool spots are on the aluminium window frames. If these are insulated with the use of uPVC, then the next cool spot will be the glazing itself. My experience so far is that the glass very seldom shows any condensation, even when it is very cold.
An analysis of this FACT, seems to suggest that, at worst, I'll get a few more degrees of outside chill before I get condensation on the glass. At best I may eliminate it.
You can try a little experiment yourself. Take two identical glasses, put one in the fridge and one in your general living space, leave them for 24 hours. Now take the one that has been in your general living space and breath on it - the probability is that you will get no condensation. Take the one from the fridge, and it will probably start showing condensation as soon as you expose it to a warm room - if not, just breath on it and you will see condensation.
What you have just demonstrated is localised cooling, which can be eliminated.
In answer to your questions on Aluminium vs Upvc...Aluminium is a metal and inherently colder than upvc.
This I would really like to see. Please take a piece of uPVC and a piece of raw aluminium, place them in the same environment for 24 hours, then take a thermometer and measure the temperature of each. What you will find is that they are at exactly the same temperature.
The reason aluminium "feels" cooler than uPVC is that the former is a good conductor of heat (and electricity) while the latter is not. The reason uPVC windows perform better than aluminium is again due the the conductivity properties of each compound.
As for putting a trim over the existing Aluminium, i'm afraid i can not see this helping that much, as the base frame will still be cold, so the ' trim ' will also be colder…
Again you are failing on the science here, and also ignoring the FACTS I have already presented. If you put a uPVC trim over aluminium you instantly reduce the aluminium's ability to conduct heat – or at least you insulate the warm air from the cold aluminium, which prevent condensation. Conduction is the reason the aluminium feels cold. The aluminium is transferring the cold from outside to its inside surfaces (or rather it is conducting the heat away from the inside surfaces - but we won't dwell on that issue).
I already know that using such a trim does work, because I KNOW that part of the frame that the double-glazed units sit in is raw/anodised aluminium, and this part is covered by a uPVC trim. This part does not suffer condensation issues.
What you are essentially arguing is that there is no such thing as localised cooling, and that this cannot be eliminated. I trust that I have already proven that this is wrong.
You are also basically arguing that even if you had triple or quadruple glazing you would still get condensation, or that uPVC frames would not make a difference - which is also obviously false.
I accept that if you have a damp home, you will get condensation on cold spots. But that is nothing like the same thing as trying to tackle localised cooling on surfaces that are known to be good conductors.
What I am asking is whether anyone can point me towards sources for the uPVC trim, not really whether you grasp the science or not.
