- Joined
- 27 Jan 2008
- Messages
- 25,004
- Reaction score
- 2,894
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I did work with some pneumatic hand lamps for use in confined spaces. Small air turbine generated 12 volt and powered a quartz lamp. Also hydraulic water pumps they uses swash plates so one could alter speed to match liquid being pumped. The idea of changing power method is still something to be considered with solar panels. Which will work best electric panels and immersion heater or direct water heating?
Problem is point where transfer threshold is reached. To take the water at 30°C and feed it to a heat pump (Sterling engine of course) to raise it to 60°C so it can be used for domestic water and not have problems with legionnaires is much harder than taking electric power at 30 volts turning in into AC transforming up to 230 volts and feeding an immersion heater.
For easier also consider cheaper. Manchester did have a power delivery system using hydraulics to work lifts and films of USA shows steam raising from the road so it would seem they used steam power. Working in a steel works my dad's job was to control power from a power station. This was steam, air, blast furnace gas, coke oven gas, and electricity, it was a real power station not simply an electric generating station. There has been a lot of thought into the idea of using excess heat at the moment wasted to heat homes. It is done in some places. Mount Pleasant on the Falkland Islands uses the waste heat from power station which is boosted a little then heats the accommodation block and also heats the fresh water because it was too cold for the chemical to clean the peat from the water.
We already have central heating boilers with sterling engines which turn excess heat into electric power which is fed into grid same way as solar. As to how good external combustion engines are I don't know, but again the wispergen is used with boats.
