Well, I've put together a few bits and pieces from various threads and ...
Determined that if the service is PME then the DNO is responsible for providing and maintaining an earth. But "DIY conversions" aren't unknown so just the presence of an earth connection to the service head doesn't mean it's officially PME. And as the installation has had "a few changes" over the years, and I've seen evidence that it once had an earth rod (separate from the lightning conductor), I thought it might be interesting to see if the DNO could confirm it is PME.
And since the service fuse isn't accessible to see the rating without breaking the seal, the responsible approach would be to ask the DNO. There's been a few comments in threads along the lines of "and what was agreed with the DNO regarding connected loads etc".
So I asked the DNO (ENWL here) and got a reply that was basically :
"Most of the information can be provided by your electrician."
On the earthing, they then say basically "
if it's PME then these values, if not PME then other values".
On the service fuse, it says "
We do not keep these details and your electrician will be able to determine what type and amp it is."
I didn't think this was very helpful
So rather tongue in cheek, I replied along the lines of :
Please confirm that the presence of an earth connection from the service head meads that the service is officially PME
I assume that your statement constitutes approval to break the seal and remove the fuse to visually inspect the fuse. Please confirm this ?
I got replies from two people (the original person and someone else). Anyone like to speculate on what they said ?
Well probably not
One helpfully said that they would forward the request to the connections team to see what was originally installed - but they have no record of any later changes. That latter bit doesn't sound very useful - if true then it means they really have a big gap in their records of what the network is.
They also said that no, our electrician (I haven't told them it's me) cannot pull the fuse - I need to contact our supplier and make an appointment.
The person who sent me the original "not useful" reply said :
No we don't know anything about the fuse installed, and we've no records of ever having attended the site. And no you absolutely can't pull the fuse and have a look.
And also said that basically they have no idea what kind of earthing is installed. And goes on to explain that earth rods are installed when there's no existing earthing at the site, and the site owner is responsible for the cost of installing one, etc.
TBH I wasn't expecting a useful reply. But it does seem strange that they can't answer basically safety related questions about the service they provide
As it is, I think I might know someone with authorisation to pull the fuse and reseal it as a foreigner without having to go through the palaver of getting our supplier to contact the DNO etc.
