Reliability alone probably the intergas but the Atag is more efficient due to the flue heat recovery built in.
That pretty much summarizes the situation. The Intergas is different to most current combi's, in that it has no secondary heat exchanger for the DHW, and therefore no diverter valve. It's Aluminium heat exchanger has two separate pipes embedded/running through it, one for the CH loop, and a narrower one for DHW. This mechanically-elegant design means fewer parts to go wrong compared to other combi's.
The intergas's concept is not a new one, as my mother has a 20 year old Combi using the same principle. Of course the technology employed in the intergas is
much newer.
Apparently the heat exchanger's DHW pipe can suffer a build up of limescale, as the water sitting in it is heated to a high enough temperature when the central heating burns to bring the minerals out of solution. I don't know practically how much of a problem this may be; Dan will advise you accordingly. I have also heard that the Wilo pumps used on the intergas are not great reliability-wise, but stand to be corrected on that.... again Dan?
The Atag conversely has a stainless steel primary heat exchanger, and is like most other combi's, with a diverter valve which upon demand diverts the system's water through a secondary heat exchanger to instantaneously heat the DHW. More parts to fail than the intergas, but only a comparable number of components to most other combi boilers.
I believe that failed diverter valves are often attributable to crap floating around the system (Sludge, and non-metallic particles etc...), which is one reason a boiler manufacturer may insist your existing system is power-flushed for their boiler warranty to be valid. Most also either mandate or at least recommended a system filter on the CH return pipe close to the boiler, and an inhibiter chemical in the system.
Ultimately I opted for the roughly 10% greater DHW efficiency of the Atag, knowing that there are more mechanical components that
could fail in comparison to the Intergas.
With all of the above considered, the manufacturing quality of both of these Dutch boilers is regarded as first rate, so you are buying a damned good boiler regardless of which one you go for.
You pays your money, you takes your choice.
regards
Craig
