Super heated steam? The safety valves, pressure and temperature, are supposed to activate before that situation arises.
Glad you think so.
The PRV is a safety device and not covered by the boiler manufactures regs, so other than saying it should discharge safely thats good enough.
The regs will say that in the event it does discharge it should be visible.
This thread states that all boilers can have their pressure relief valves connected to a HepvO trap. Part g of the building regs approves it.
//www.diynot.com/forums/viewtopic.php?t=249310&start=15[/QUOTE]
Can you tell me where its states that all boilers can have there PRVs run in plastic in document G?
No, I was just pointing people to the thread. It does mention the atag.
Glad you think so.
I look it up from a table. Duh! It's child play!
What does this 'table' suggest?
What it says.
What it says.
The table does not say anything although it might suggest something so what did the table suggest?
Did you consult this table before or after your suggestion regards using 28mm headers?
Getting tired of your nonsense
What was the question again???
The only nonsense is from you. You have contributed sweet nothing to then thread.
In domestic situations with a house not that large, 28mm was the size used that I saw.
Using 28mm, as 35mm pipe horrendously expensive, two 28mm distribution identical sized headers can be used. One for each CH zone. The boiler's flow and return pipes tee into each header, making sure the length of the flow and return pipes to each header from the boiler the same length. .
When I feel it is worth it I will contribute something ,
That you SAW? , please.
No reason whatsoever why primary flow/return can't be of a different length.
Nonsense !!! With two headers and one boiler the Flow and Returns from each boiler should be ideally the same length as one header may grab more flow than the other. Otherwise it is a matter of putting in a balancing valve on each header, which adds complexity. Now you know. All child's play. Keep your attitude your yourself. Or keep reading as you will learn something.
