How do you think industrial design would have fared in fared in this country without steel reinforced concrete in bridges car parks etc, exactly the same principle and susceptibility to manufacturing and installation faults.It's predominantly flat roof "planks" which are the problem. They've been used since the 50's, and were expected to have a 30 year life. Well it's only 70 odd years, so why on earth should there be a problem...
There have been warnings since the 90's.
Fitters often didn't use a long enough bearing distance (some were specc'ed at 45mm but the planks didn't get it)
The design is crap, it's asking for failure.
The stuff is effectively porous, hence its weight increases a lot due to the amount of water it holds.
And the thermal insulation thereby fails.
The surface cracks and spalls and plants grow.
Where there's reinforcement, the bond to the concrete fails - small movements crunch it.
Yes the steel will rust .
All concrete weathers - rain is slightly acidic, and it has an effect on the chemistry. The pores join up.
People walk on roofs when they shouldn't, people drill holes through it, and on and on.
Plain dumb design and heads in the sand.
Blup
