How reliable is the bored operator, reading the paper or on farcebook on his phone, in the event it's required to stop the pump to prevent injury ? Can you quantify that reliability with a number ?
No ? Thought not.
And, can you cite reasonable events where stopping the pump is required to avoid injury ? Do you know what the system actually is that's being discussed ?
No need to quantify with a number, in fact there is no need to do anything unless you have decided that you want a control system involved in running this pump. At which point it needs to be done correctly.
You really are a glass empty person aren't you !
You criticise anyone for considering a system without all those numbers, but you refuse to accept that there is already a system in place without those numbers. A system which is far from reliable or failsafe.
What if your transmitter electronics fails such that it keeps sending the signal to keep pumping, because it ignores the OFF switch or any other button you press?
What if the receiver electronics fails such that it holds the pump run output high, regardless of not receiving anything from the transmitter.
What if the hydraulic valve sticks and won't stop the pump ? What if the governor on the tractor fails and the pump runs faster ? What if ... ? What if ... ? What if the governor fails, the hydraulic valve sticks, and the stop solenoid on the tractor all fail at once ?
What's the reliability of your system? I know it's not 100%, no safety related controls are sold as 100% reliable, and don't need to be. What you need to show is that they are reliable enough in relation to the risks ...
Precisely, and I believe we've shown that
compared to the manual system it no worse.
What if the operator falls asleep ? What if he goes for a "call of nature" ? What if he's just watching something else and misses a visual signal ?
As you should be aware, a manual system is very error prone - which is why manual systems are reduced or eliminated wherever practical.
Even if you went for a wired system, what are the risks there ? How would
YOU wire such a system ? Would you wire an E-stop style NC circuit where the pump stops if the circuit is OC ? Would you wire it to require 3 wires, one OC, one NC, anything else is an error ? How would you deal with the inevitable electrical faults that result in the operator stripping the cable back and twisting the wires together ? How would you deal with failure of the electronics ? One thing I am certain of, is that a cabled system
WOULD fail in the field (pun only partially intended) - it's a harsh environment out there. Without putting any figures on it, I'd put my money on a radio system (even using public frequencies like PMR446 or CB) being far far more reliable than a wired system.
But, as I've hinted at above, it's clear that you are treating this as "some random mechanical system" without any understanding of what it is, how it's used, or what the risks actually are - actually looking back, you'd hinted at it ("I don't know what pressure" - hint, it's very low, it's about flow not pressure) and stated it explicitly ("I don't know about agricultural systems"). The actual risks of personal injury are very low - this isn't some machine that will pull you in and spit out the mulch, in fact it's hard to see how personal injury could occur without the operator being just plain stupid. In the grand scheme of things, there are far bigger risks to worry about.
If the pump fails to stop when commanded, then the operator just continues spreading the sh1t until it does. He'd have to ignore the fact that the pump failed to stop and then start uncoupling pipes - would you consider it "reasonable" to try and allow for a situation where someone deliberately does that ? In this case I wouldn't.
If some event happens (not high probability)
and another event happens such as failure of the controls (not high probability)
AT THE SAME TIME (so even lower probability) then the operator drives back to the yard and stops the pump. Problem solves, the "backup" procedure takes over.
IF he's spreading somewhere higher risk, such as right next to a watercourse, then he'd still have the option of a second operator to stop the pump in an event and not wanting to leave the pump running for the time it takes to drive back.
PS - how many radios continue transmitting without a power source ?
