I'd have to do some sums to be sure, but I'm far from convinced that what you say is necessarily correct. Words like 'moisture' and 'humidity' are being used in rather loose ways. What determines whether condensation will occur is the relationship between temperature and water content of the air. If the total water content of the air in the room is reduced AND the temperature of the air is also reduced, then whether or not condensation results will depend upon the relative degrees of reduction in water content and reduction in temperature.
Yes, it will but you may be getting too technical for a person complaining of mouldy bathrooms.
As the air in a bathroom will be 'steamy' (full of visible water vapour) and the air coming in will not be then I think the result is going to be as I have thought.
That's not actually the case. Although my house is fairly draughty, a lot of it is also cold. Condensation in bathrooms (and sometimes other rooms!) on walls, ceilings, mirrors, shower cubicle walls etc. is therefore quite common.
Well, it will be; that is inevitable.
However, what happens after that is the determining factor.
As above, temperatures are as important as air water content. However, despite the condensation, we've almost never had any mould problems - which is why I previously said that I don't really understand why 'mould experiences' seem to differ so much between properties.
You have said it is quite draughty and you have chimneys.
Once one has the condensation, all one can do is to do things to cause it to evaporate, and raising the temperature (hence dew point) is the best way. When one tries to get rid of it, disappearance of the condensation is usually very slow until the the air being blown by the car's heater/fan gets hot - it would take a long time if one tried to do it simply by replacing the air within the car with cold, but dryer, air - try demisting your windscreen with the 'heater' set to 'cold'!
It depends how long you wait. You probably would find half an hour sat waiting unacceptable but in a bathroom it would be fine.
Conversely, are you saying that a fan alone is useless?
Would this, if so, apply to extractor fans?
In my bathroom, after a bath, the tiled walls are covered in condensation - not running with - and half an hour later it is gone without opening the window or having a fan.
Mould appears where the surface
never dries.
I maintain that the problems occur where the rest of the property is also, and always, humid - caused by the inhabitants - because of things like lots of plants, lots of washing and cooking, even many people, the bathroom may have been wiped and the cloth containing the water just left there..
I have been to properties I look after where the tenant has complained of mould and when you walk in it feels like the tropical house at the zoo.
Once the bath was left full of water, I do not know why it was not drained - didn't bother to ask.
None of the properties has a problem when empty.
Obviously, some places have other issues with actual leaks entering.
Also, perhaps some people worry about 'your and my type of condensation' because they think none should occur and they should be able to see in the mirror when they get out of the bath when, in fact, it is not a problem at all - it is just what happens.
It's like dust; if you don't remove it, it will just increase.
