Maybe. Of course, there's no such thing as 'visible water vapour' - you see 'steam' when condensation has occurred, because the RH has, at least locally, exceeded 100% for the temperature of the air. In theory, the outside air could be 'steamy' because of its low temperature, even though its actual water content (absolute humidity) was very low - look out of your window when there is a cold dawnYes, it will but you may be getting too technical for a person complaining of mouldy bathrooms. As the air in a bathroom will be 'steamy' (full of visible water vapour) and the air coming in will not be then I think the result is going to be as I have thought.
As I said, preventing condensation and getting rid of it once it has occurred are really two different issues. Once one has got condensation (liquid water droplets) on walls, windscreen or whatever, on can only get rid of it by encouraging evaporation, and the best way of doing that is to increase the temperature of the air passing over it. If one is (by means of an extractor fan or car 'heater') replacing the air in the room/car with cold air from outside, the already-existing condensation may ever be eradicated. Although that outside air will (because of its low temperature) often have a very small (absolute) water vapour content, it may (again because of its low temp) have a very high RH, and therefore unable to 'accommodate' very much additional water evaporated from the condensation. If the extracted air is being replaced by warm air (probably with only 'modest' RH) from the rest of the house, then it's much more likely that the condensation will evaporate.It depends how long you wait. You probably would find half an hour sat waiting unacceptable but in a bathroom it would be fine. Conversely, are you saying that a fan alone is useless? ... Would this, if so, apply to extractor fans?- try demisting your windscreen with the 'heater' set to 'cold'!
That may well be true.I maintain that the problems occur where the rest of the property is also, and always, humid - caused by the inhabitants - because of things like lots of plants, lots of washing and cooking, even many people, the bathroom may have been wiped and the cloth containing the water just left there.
Kind Regards, John
