Ok
Your link was dead but if you say it’s suitable then me not being able to clink the link is fine.
I was going thinking that this new light has a flat metal base which I suppose screws direct to the ceiling. So does that mean that all these wires I’m going to see should be brought through the hole in the light then joined. Normally you would make the joins in the ceiling rose and have a pendant or more space to do this.
Is something then supposed to go between the light and ceiling ?
No.
The advice is to stay at home, unless (amongst others) you are exercising, shopping, seeking medical assistance or medications OR TO GO TO WORK IF YOU CANNOT WORK FROM HOME.
