the only way to see if it is goosed is to try and pump it up, if it is burst you will hear it straight away
Hi so the filling loop pipe line which goes to the 22mm left side in pic this is not where you would connect a remote vessel as that is a feed into boiler?That vessel appears to be goosed then, although that could be condensation. No harm in re-pressurising it and see if the bladder is intact. Don't connect a new vessel where your red arrow is!The pipe to the RHS is the ch return (the one with the drain off on). Connect it into there if you need it.
Is your boiler still working ?
Hi so did yours have the same issue where the pin does not come out enough to push the micro switch , and this kit fixed that problem or your DV was leaking ?It's easy to take to bits . Loads of videos on YouTub
Ok I will give it a go and see if it cures my problem,I had the pin problem a couple of years ago , when you take the diverter valve apart be careful the spring will fly out ( mine was covered in limescale ) give it a good clean and replace the diaphragm. It worked for me . My expansion vessel either needs pumping up or replacing
Did you take the water pressure to 0 before you pumped it up ? What did you pump it up to ?(1 bar )Ok I will give it a go and see if it cures my problem,
Yes I would try pumping your vessel up and see if it stays pressurised over a few days.
Depressurise the system by draining and gauge on 0 then I pumped vessel to around 0.8 bar .Did you take the water pressure to 0 before you pumped it up ? What did you pump it up to ?(1 bar )
