A friend has just had his combi routinely serviced (worcester) by a new RGI. It was installed around 4 years ago by an eastern european guy who is no longer in the trade.
The new gas guy has isolated the fire in the lounge as he says it's dangerous. It's a Baxi Bermuda with back boiler. The back boiler had already been disconnected from the gas & water by the combi installer just leaving the front fire operational. The new guy says the combustion gases would not be able to find their way through the dead boiler properly and could spill. He suggests taking the bermuda completely and having a new fire which the owner would still like to use.
Just wondered if this is a common problem and if he's given the right advice. There's a tech bulletin on the gas safe tech library mentioning that solid fuel fires should sit in front of a disconnected solid fuel back boiler, but that's for a different reason.
