I was just thinking he may have mis-recalled the bulletin and applied it by mistake to the gas back boiler-fire front combo. There are lots of threads on the forum about people doubting an RGI's decision or ruling and most of the doubters get shot down in flames by other RGIs on here. The explanation for condemning the front fire based on the fact the boiler's disconnected puzzled me, but I'm not a gas engineer. I've since spoken to him and he's said it's because the permanent boiler pilot 'aids' the expulsion of fumes from the gas fire and if it's disconnected, a strong wind might cause spillage.T his is a modern-ish Bermuda BTW, the living flame type
The chap needs to make sure not base his judgement on assumption
Apparently he didn't light the fire. He just pulled the front bit off, bent down and tut-tutted. Had to take one of the fireglow bulbs out and didn't replace it.
He also picked up on the main earth bond to gas being more than 600mm from the meter, I think he found it in the airing cupboard and said he'd re-route it when he fitted the new fire.
I'm sure the bermuda boiler is all electronic as I remember hearing it light during a dinner party a few years ago, it went tick-tick-whoomph which tells me it was electronic ignition.
Fire has not got eletronic ignition sequence!!!
I could be wrong in which case I will stand corrected.
Good information Terry
There is a switch under the knob which powers the transformer when knob depressed, sparking commences to light the gas
