Get another RGI round.
baxi do allow it as long as the correct procedure is followed
????oh dear....
The Baxi Baroque Super and Baxi Arena Super are living
flame effect gas fires with a heat input of 5.57 kW (19,000
Btu/h) and an output of 3.40 kW (11,590 Btu/h) at its
maximum setting. The fires are available for use with Gas
Type G20 (Natural Gas) at 20mbar supply pressure. The
fires are suitable for either hearth or wall mounting and are
designed to be used on NATURAL GAS ONLY. NOTE: The
data and spillage test labels are located on the inner fire
support feet behind the fender front.
Electronic ignition is provided to light the pilot. The fire is
controlled by a control knob positioned on the right hand side
of the case. This control knob has six positions giving a
choice of four output settings.
Position
Position
Position
Position
2
Position
3
Position
4
The artificial coal bed may be illuminated by concealed bulbs
as and when required. The light effect is operated by a
switch situated below the control knob. It may be used
whether the fire is ON or OFF
oh dear....
Why would you post that as the OP?
Another wind up merchant ?
Good morning
There is no legislation prohibiting the decommissioning of a backboiler leaving the firefront in use, however, we do not recommend the practise. Whilst there are no concerns regarding safety in use if the work is carried out properly there are concerns over the possible effects of corrosion to the flue components if servicing is not regularly and properly carried out. If decommissioning is to go ahead we recommend the procedure as laid out in Gas Safe bulletin 091, this is comprehensive on the work involved.
Kind regards
Jonathan Smith
Steady on. If you'd read the whole thread
