FredFlintstone said:steve1811uk said:Glad it went well with the BCO. Just a few questions really as I'll be meeting up with the BCO in April. Is he coming back or is that it? Did you attach the sockets etc. to the wiring or have you still got to do that? What conduit did you use? How did you fix that conduit to the wall? and finally how do you plan on covering the conduit wiring? Hope I do as well on my BCO visit. Steve.
Hi Steve,
BCO is coming back. This was first fix inspection. Concentrating solely on the installation and routing of the cabling with no sockets or fixings connected or anything. He looked at absolutely everything, tracing cables up the wall, across ceilings, through joists, down other walls etc. He commented on some existing cabling that passes over heating pipes etc which I'm already aware of and which I'll be rectifying although he did say that he was just commenting on this - he can't force me to fix it.
There was a bit which I'd already covered up (oops) which he was happy to pass based upon searching for the cables behind the plasterboard with a detector and based upon the fact that he was happy with the rest of the installation. He pointed out that he could, if he so wanted, make me uncover them for him to inspect. This comes back to the point about if they feel you're taking them for a ride. Because I'm open and honest and not trying to hide anything, they have no reason to believe I'm trying to hide anything, they just realise I was a bit too keen to get the bare brick covered.
I used a mixture of conduit. I had a huge overstock of that rectangular stuff with the removable top from some work that was done in my office so I mainly used that because it's easy to fix to the wall, run the cable and then stick the capping on. It also had the added advantage that the capping can be removed so the BCO could inspect the cable itself (something which I didn't think he'd do. I thought he'd just want to see the route of the cable but maybe he was just being nosey. I fixed this conduit to the wall with screws and just stick a little bit of insulation tape over the screw head in case it chaffed the cables.
I also used a bit of oval conduit and fixed that to the wall with conduit clips. I only used this on short runs though because I figured it was easier with the rectangular stuff.
I'll be covering the conduit with plasterboard, dot n dab. I know that means the plasterboard will be further from the wall than if I'd chased the conduit into the brickwork but, the walls aren't level and I would have had to leave this gap anyway to ensure the walls were plumb. There is one wall which I will float and set over the conduit and this has the same plumb issues anyway.
BCO will be back again. I've got to let them know when I'll be ready for them and they will come and inspect the new wiring with the accessories attached. I need to speak to them about this though because I'm a little unclear of I should be doing this, getting them back for the next inspection and then doing the CU or if I should be doing the CU at the same time so it can be inspected along with the new circuits at the same time.
Good luck with your BCO inspection. Nothing to be scared of (although I wasn't thinking that the ight before the inspection). Just be open and honest and if you have any questions then line 'em up for the BCO - they're very helpful.
Regards
Fred.
Thanks Fred for the tips. I'm doing a similar job to you and am a bit apprehensive about the BCO as I guess you were too. I plan to use dot and dab with plasterboard too as the plastering on my main kitchen wall is attrocious and can't afford a plasterer. I was going to clip the cables directly to the brick but I may use the oval conduit like you did in order to make future modifications easier. Or I may use capping, it should be possible to pull cables through that I think. My biggest problem will be trying to get the whole new kitchen completed in a week (taking a week off work) as the BCO inspections will definitely hold things up. I've also got the CU to fit as well ! Don't know in what light the BCO will look at that job. Steve.
