he already said this is not an option since the missus don't know how to change a plug yet alone unwire and re-wire a fridge into a flex outlet...
also I would stick with the switched fused spur above the counter for quick isolation should a fault occur..
if you thought he had just DP switches above the counter then naughty boys... if you're gonna spur off a ring, use a FCU unless your spur is in 4mm..
