If the oil nozzle is wet, then this suggests that solenoid is opening during ignition phase. The one thing you have ignored is what oil pressure are you getting at the pump? This could be your problem given what you have changed.
Thanks for response
Could you tell me what voltage I should be getting at the coil when burner is been called for as I seem to be only getting 70 volts
