hi
discovered a problem at the company where i work and would like some advice on possible solutions please so i know what im looking at before i go and tell the boss!
what we have is a 3 phase supply that goes through a fused isolator (3x800amp bs88 fuses). after this it splits via a bb chamber and feeds 3x200amp db's, 2 office supplys(45amp each), a 30amp sub main and another db at 300 amp.
there is also a bussbar fed directly from the main fused isolator which is wired in swa 4 core 120mm. the bussbar i believe is rated at 300 amp and has 10x30 amp isolators and socket outlets on it.
i think your getting the theme here that im a bit concerned the whole installation is overloaded! ( this came about as its been suggested that some more points be added from the bussbar to power a 100 amp machine!)
thing is what is the 120mm cable (for the bussbar) rated at? sureely its not sufficient to be protected by 800amp fuses?
is it time to take a trip to the boss's office to tell her she should be concerned?
