I would base it on some at least not being sure what is driving the SL in the circuit so far as the fan is concerned so might assume thec same rules as for the Perm L , which at least is logical on its simplest level so to assume the same aplies for both I would not criticise.I've already commented on that, and my answer (in terms of 'electrical common sense') was essentially 'no' - on the basis that the only two situations I could think of that would/could cause overcurrent in the S/L feed (a 'new path' from the S/L terminal 'appearing', or the input resistor "failing S/C") would both seem to be 'incredibly improbable'.
You will not believe this (I didn`t so I asked him to repeat it just incase I missheard, no one else picked him up either), a tutor stated that on SELV timed overun the fan control had two transformers inside.
When I enquired why two transformers not one he replied that that one transformer was supplying 12v for the perm supply and the other one for the timed overrun part of it.
He seemed a bit lost when I retorted, take a mains fan with timed overun (one supply) and remove the fan, then replace it with a 12v transformer then connect a 12v fan to it "how many transformers now?" .
I am not kidding.
