Black paint on the bricks
11 Dec 2018
Hello
I've recently moved into a 1910-20 end of tarraced house. The house is build with solid brick walls, and concrete floor on the ground floor.
On the outside it's has pebbledash render, and the bottom few rows of the bricks is painted with black paint, presumably bitumen paint or something similar.
However, as you see on the photos the paint is flaking in many places and mortar is missing in few palces too.
There is also a gutter downpipe going directly into drain. The gutter is cleaned and drain seems to be fine too. However In that corner inside the house there are signs of damp. Probably from the splashback and missing mortar.
I want to repoint the mortar in between the bricks, but not sure what to do about the paint. How to remove it in order to properly repoint.
Thanks in advance for any suggestion.
You could try a pressure washer. Beyond that sand-blasting will definitely take the paint off, but will also take the surface of the bricks off, leaving them very porous.
It's a shame it was done, it will be as likely to keep damp in as keep it out.
Grind or chisel out the joint, you don't need to specifically remove the paint. Then repaint.
Peelaway
It's paint remover.
Don't seal the bricks with paint.
Take care; I had an asbestos survey done on a building I use, and the surveyor said that a thick line of bitumen-looking paint on the bricks was one thing he would send for asbestos testing if there were plans for it to be disturbed..
If you don't know how long the paint has been there perhaps avoid operations that would see it being reduced to airborne dust unless it's tested to be safe
If you leave it, it will erode away in 50 years or so.
It is usually applied to hide (it does not cure) damp at the foot of a wall. Actually it makes it worse, by preventing water evaporating out of the bricks.
The cause is probably nearby, usually a broken or leaking drain or pipe, or incorrectly laid concrete or paving that bridges the DPC and/or slopes making water puddle against the house.
Very noticeably, in your cases there is a old downpipe next to the damp patch, and the paving level looks like it was raised since the house was built.
Digging round the pipe will probably find a drain fault, and you will also be able to find the original DPC.
In old houses, the lime mortar below ground is often washed away by long term leaks. You can clean out the mud and repoint using cement mortar. You do not need to use lime below ground because it will not "breathe."
Do not allow anybody who sells silicone injections near your house.
It's very unlikely to contain asbestos. That would be the thick goo that was used under floor tiles or parquet, the asbestos fibres were to strengthen and thicken it.
If there's asbestos then it probably wouldn't have flaked off, and you'd see the fibres poking out if it had.
