Unfortunately, I suspect I may know the answer to this question, but.....
We have a downstairs rad that refuses to warm up. All other rads in the house are fine.
The rad has been removed and flushed clean - very mucky and sludgy inside.
We refitted the rad and it fills fine from the TRV (the return, judging by the direction of the arrow) but it does not fill if we empty the rad again and open the flow valve.
At the risk of flooding the hallway, we removed the rad (again) and opened the flow valve. The valve mechanism screws itself open OK but the flow of water is barely a trickle.
The pipe feeding the flow valve gets very hot very quickly so I suspect there may be a blockage either in the valve or in the pipework close to the valve.
I really need to get the valve off to inspect it and the pipework leading to it. Is this going to require a full system drain down or is there some 'sneaky' method of localised flushing (hosepipe / compressed air etc) which might shift the obstruction ??
Or is trying to flush a blockage in CH pipework not a good idea as it may just transport the problem elsewhere in the system ?
Many thanks for any advice....
