OK if you guys have got that out of your sytems - can I ask you to concentrate on mine and let me remind you of my very first post: -
I have flushed the system using the fill loop at the boiler.
By closing the CH flow isolation valve under the boiler I can get a good flush down the return pipe, through the rads (5 mins each in turn) and out the drain-valve which is next to the TRV on the kitchen rad.
However, closing the CH return and opening the CH flow means the water is now going through the main heat exchanger etc before going down the flow pipe and out the drain. Result is a much smaller amount out of the end of the drain hose.
Do I really need to take a radiator off to do it again !!!?
