System is oil-fired (Worcester Heatslave). Everything was fitted in 1995 when the house was built. The pipes feeding the radiators are 10mm, a mixture of copper and plastic. Some of the radiators barely get warm. (Rooms furthest from the boiler).
For one room, I was able to pull up the carpet and floor boards and replace the plastic pipe run from its manifold to the affected radiator. The pipe was full of black, crystalline "sludge". It was quite hard "sludge" though. It made cracking noises when I tried bending the pipe. I put corrosion inhibitor into the system after doing that job.
Sadly, the pipe run to the other radiator is longer, and runs under a cork tiled floor which has been glued to plywood, which in turn, has been nailed to the T&G chipboard floor, so pulling it up would be a massive undertaking!
Are there any tips and tricks for this sort of problem, please? I was wondering about giving the system a heavy dose of Fernox or Sentinel cleaner? I've also seen adverts for a device called a "magnaclean" but presumably, that wouldn't do anything once the pipe is blocked? (It's not completely blocked - not yet, at least)! Does powerflushing work?
