I have a Worcester greenstar 28 CDI compact.
My nest didn't turn the heating on tonight in time for us to get home so it was 16 degrees rather than the 22 the missus likes.
By half 9 the house still hadn't hit the target temp which seemed odd so I went to look at the boiler. The blue light was on but it wasn't firing despite the nest telling it to.
I checked the manual and found the instructions to get into the info menu and the status was 'anti cycling mode'.
Googling indicates that this is to prevent the boiler overheating and it happens when the boiler is set to a higher heat output than the total of the rads. Is that correct?
I've checked the boiler and it's set to 24kwh on the ch. I've added up the kwh values of my rads and it comes to 13kwh.
Does this mean I should turn the ch down to 13 to prevent anti cycling, decrease heat up time and increase efficiency?
Boilers not new and I've only ever noticed this once before (when the house was heading from 12), but the rest of the time the heating comes on before we get in.
