- Joined
- 18 Mar 2008
- Messages
- 1,488
- Reaction score
- 1,064
- Country
Thanks for your thanks!
Basically if the boiler is reaching temperature before the house does, a few things are happening. The radiators are not sized correctly (too small), the system isn’t balanced correctly (including setting of any external bypass), or the pump is too slow. Now when you drop the Kw output at D.0 the pump speed will be dropped as well, this doesn’t always suit the system, so depending on which year your 637 is manufactured there are two ways to adjust this. Either D.19 (set to 3 (not 2)) or D.14 (set to 5 or 100%). As its a system boiler, I would also recommend you have the flow temperature a bit higher, say 65ºC as it will stop it short cycling too much when heating the cylinder, which I presume you’ve got set to 50-55ºC?
There are other factors, but its best to try these things one at a time.
Let us know how you get on.
