I posted about this some months ago so apologies if it's a bit of a repeat, but I've got updates.
Basically, I have a Potterton Suprima, small tank in the loft F&E, hot water tank upstairs in airing cupboard.
Bought the house 9 months ago and I turned the gas off straight off and the heating stayed off for 4 months. Some changes to pipe work, ie moving rads, and all new rads put on. When turned back on the boiler kept overheating and locking out. Engineer came out and changed the thermistor. No luck. Eventually found the the 'aerator' (small tin can looking thing with 3 pipes coming out of it) was blocked solid with sediment. When attaching the hose one end, nothing came out of the other two ends. Cleared it, back in. And the boiler worked. Sort of. Just kept firing up for a few minutes then stopping for a few minutes.
I've now had a new Grundfos pump fitted. Still the same problem. Have put a couple of bottles of X100 or whatever number it was, prior to the new pump to try and clean it. Still doing it.
Where do I go from here? Is it likely to be another partial blockage somewhere?
I've put the heating on tonight (trying to balance the rads after having bathroom towel rad fitted). I timed the boiler and below is the times of on and off;
On - 2m52s
Off - 2m12s
On - 1m22s
Off - 2m12s
On - 1m02s
Off - 2m12s
On - 50s
Off - 2m30
On - 40s
Off - 2m39s
On - 39s
Then I gave up but it's still doing it now.
I really don't get boilers and central heating but it seems as though the boiler is reaching the max temp in similar times at the start so shuts down? Then takes similar times to cool down enough to fire back up?
I will get an engineer back round but any heads up of possible causes would be great.
Thanks for reading and sorry for the ramble
Fordy
On - 2m52s
Off - 2m12s
On - 1m22s
Off - 2m12s
On - 1m02s
Off - 2m12s
On - 50s
Off - 2m30
On - 40s
Off - 2m39s
On - 39s
Fordy
