I have a gloworm 24hxi and a danoff timer. I can set the timer and it all seems to light up when it should but .... It will turn the heating and water on but wont switch off again. Any ideas?
Is this an existing system that has started doing this or a new install ?
Are you sure it is not just pump run on or an economiser mode to take out excess heat from the boiler ?
