Is this OK or am I doing damage to my boiler somehow? The set up is:
I have been trying to estimate the flow I'm achieving from looking at the pump curve, but to do this I understand I need to know the system's total pressure loss. The boiler manual states that it has 0.5 metres pressure loss at the min. 600 l/ph, but I don't know how to estimate the rest of the system's resistance. Is there a rule of thumb I could use?
If I instead work backwards from the temperature difference and the gas used - a 21c rise with approximately 11kW gas going in (according to smart meter), the flow rate is 450 l/ph (450/60 mins*21 c temp rise/100*7). That's well below the 600l/ph minimum rate specified for the lowest modulation possible according to the installation manual, so my questions are:
1) Is the boiler still condensing? It sounds as though it wouldn't need to based on the heat output - is heat being wasted somehow?
2) Is exceeding the minimum flow rate causing damage to the boiler?
As I say, there's no cycling, the boiler just burbles away on what I presume is it's the lowest setting. The downside is that the system takes rather a long time to get up to temperature, but moving the pump speed up a notch reduces my return flow temperatures to 55+. Lowering the boiler temperature to compensate not an option as the house fails to warm up.
Big thanks to everyone here for sharing their expertise - I have learnt quite a lot over the last couple of weeks trying to optimise my system.
- British gas 330+ (min flow rate of 600l/ph quoted for 10kW lowest modulation)
- Grundfos 15-60 130 super selectric pump (on lowest setting, max 2.2 metres head)
- Flow temperature - 71c
- Return flow - 50c
- 8 radiators
- 3 bed detached
- Have balanced the system - all radiators get up to temperature at the same rate with roughly the same temperature drop
