I've had my first quote for a new boiler installation and I nearly fell over when I read it. I will be getting more quotes but is this high or am I out of touch??
Flush heating system Remove existing boiler supply and install new primary heating pipework from current boiler position to new boiler position in extension.
Supply and install Worcester Danesmoor utility 25/32 system boiler in extension with 7 year Guarantee.
Supply and install Tiger Loop.
Supply and install 90 degree rated fire valve.
Supply and install flue outside and up past eaves.
Supply and install cabling from current boiler to new boiler position.
Add inhibitor.
Commission new boiler.
Total inc. VAT: £5760
The boiler itself is available for under £2000 inc VAT so we are looking at around £3800 of labour and other parts (£3166 exc VAT)
This installation is as part of an extension and remodelling and I also want to get an unvented cylinder installed along with four new rads and kitchen, utility, and wet room plumbing.
He suggested he would quote for fitting the new boiler in a new location first and then the rest later, not sure why as I would prefer to get it all done in one go.
But anyway, if the boiler installation is going to cost this much I might have to rethink the rest of it as it will blow a hole in my budget!
The boiler will require around 6m of new pipework to extend from existing location to the new one.
Thoughts?
Add inhibitor.
Thoughts?
