No
"The output (carrying capacity) through a pipe of a given size is related to the resistance through the pipe and fittings and the velocity at which the water travels."
More length = more resistance
The figures the OP quoted will work on any domestic system over whatever lengths you would normally encounter and are a quick, easy, guaranteed way to work. No calculations required. Keeping it simple.
The actual calculated capacity is higher but the man on the job often does not have the time or knowledge to work it out.
