- Joined
- 5 Mar 2020
- Messages
- 23
- Reaction score
- 0
- Country
Had a bit of work done in the bathroom upstairs including a new sink put in. The cold water in feed valve under the sink has been fine in the 2 years we've lived here so far. It turned off fine to shut off the supply to fit the sink, and appeared fine immediately after installation and being turned back on.
It was turned back on and all looked OK Friday pm. Saturday 11am ish I notice water dripping from the ceiling and as luck would have it, straight onto the boiler. Boiler was still on at this point so I immediately switched it off at the isolation switch.
Managed to identify the valve upstairs as the source of the leak and switch it to off position, where it stopped leaking. So it leaked while in the on position, despite having not leaked from the on position for a long time prior to this job.
At no time was there any significant amount of water, just a slow steady drip, probably for about 20 minutes.
The next day the boiler looked completely dry, couldn't see any moisture inside or out or behind it so I tried to turn it on. Immediate 'clack', and the fuse in the boiler went. Bummer. That was Sunday morning. The inside cover of the boiler panel had a spare fuse, which I tried this morning (Monday) after another 24 hours of drying out in this ridiculously hot weather, and it did the same thing. This time with the cover off, I could see a flash on this component, circled in red. Boiler fuse is under where the red arrow is.
Fuse says on it T2AH250VP. I assume I can grab anything that matches that when I google it to replace?
Boiler is a Worcester Greenstar 12 Ri
A few questions.
A few questions.
- I tried to persuade the guy to change the once-leaking valve but he said now it's all OK in on position, that best off not moving it again because it was fine for ages and now having not leaked for 48 hours we're clear. Should I be happy with this? Are all valves a bit like this and once they're in the right place they're fine? Or should he definitely be replacing this?
- What is that component in the boiler, and what is the way to fix it? I suppose I just have to call out a boiler specialist?
- I have British Gas homecare cover, which says it covers boiler breakdowns for parts and labour. It is not clear whether I am covered for situations like this, does anyone know the answer? It seems to say I'm covered if my boiler breaksdown, but doesn't mention anything about cause.
- How much can/should I pin this on the guy who carried it out? It's a bit of a mystery how it happened a while after it was installed, thinking about it it might have been when we first ran the taps upstairs. Is that something he should have tested more thoroughly and found? I've not paid the last 20% of the bill yet, should I withhold that for the time being?
