Thanks everyone for your speedy replies... I'll be looking into the suggestions. : )
I took out the new brake pads, and attempted to g-clamp and tap the piston in even further. No luck. It's only sticking out about 1mm as it is, and may not go back in any further?
No because youre inside the car and the caliper is outside the car though if you had an assistant push the pedal you would see the piston move slightly, and retract slightly when the pedal was released. It doesnt fly out, and it doesnt move by much, because if it did you wouldnt be able to get much force when braking (you may remember force/distance multipliers from physics)- If I pressed the brake pedal in, would I see the piston moving? With caliper detached from brake disc.
It might not be supposed to tighten all the way into what you think is "in" depending on the bearing design. Further, given that most brake discs are held in place by the wheel nuts, they do not make a good place to grasp ahold of when doing wiggle tests. If your wheel bearing is worn to the point that you could discern an obvious amount of movement by wiggling the wheel (note I said wheel to imply you should bolt the wheel back on, not wigggle the brake disc), you'd most certainly hear a horrendously loud, constant grumbling noise while driving, worsening round corners that load the wheel up, and lessening round corners that remove load from the wheel (worn driver side bearning, louder grumbles round left hand bends, quieter round right handers)Also, if I hold the brake disc as 12 and 6 o'clock positions, i can judder it slightly. Same happened with the old brake disc which people said could be the bearing. I may be confused, but I think it's actually this nut which is not tightening all the way in:
It depends on the design of the bearing and the construction of the wheel hub. If you can post a video of you wiggling what you think is a problem, it would be more helpful. Do not attempt to tighten or slacken this nut if you have not done so already. The manufacturer's torque it is to be set to should be followed precisely to avoid premature bearing wearIt's got to a point and won't go any further so no wonder there's a mm gap for the disc assembly to rock slightly. But is that to do with the wheel bearing?
It normally looks like a flower or might be called macro, the zoom should be a Wide as possible (zoom out) and you should not go any closer than the focal distance the camera manufacturer specified. Further you should ensure youre using the 2 stage push of the shutter button correctly and that youre holding the camera still if flash is not in use. If the camera provides an indication that it has acquired a good focus lock, then ensure it has. On my camera, the crosshairs are green if it focused and red if it didnt. If you are in a low light situation, the muscular effort required to press the shutter button can shake the camera. In this case it is best to set the camera to its lowest self timer mode (mine has a 2 second timer), press the button to focus, take the shot and then while the camera is counting down to take the photo, keep still and breathe out slowly (holding your breath or breathing in inhibits your ability to keep steady - learned this in rifle shooting class)I need to figure out what setting on my digital camera will allow me to take photos up close, and not come out blurred (currently they keep the background in focus)
That is the cause of the uneven pad wear. I guarantee those brass things are supposed to float; that's why they have flexible rubber concertinas around them to keep out dirt. If they were supposed to just be a solid block then the manufacturer would NOT go to all the effort of installing a fixed brass spacer and rubber concertinas; it would just be a cast extension of the caliper itself!et Voila! One silent car!
Today I worked on the car again. I tried to push the brass bit back, but it was completely unflexible. Just would not budge.
NO NO NO. There's a golden rule in mechanics (actually in anything, apart from That One Thing):So while I was out there, another comment from this board came to mind. Filing one of the new brake pads down.
NO NO NO. Pads are supposed to work in pairs and be of the same material. You cannot guarantee that your old and new pads are matched Further, your pad is now installed in the opposite rotational direction to that which it has spent its entire life in. This can only cause problems, not be a solution.But, I thought, do I really want to loose some of a new brake pad I've just paid for? ...noticing that one of my old brake pads still hadn't worn to a minimum, there was about 3 or 4 mm left on it, I decided, how about compliment this old brake pad with a new pad in the piston.
No, it's not. If your caliper is not floating then it is not working properly or as designed. If youre not prepared to listen to any other advice I give you then please at least listen to this:Result!
Please, take your car to a professional mechanic1. I'm using an old brake pad with the new one. I thought I could perhaps wait for the new pad to naturally wear down a few mm so I could then have both new pads in the caliper to fit the wheel. However, I'm not sure as to the condition of the old pad, as it had been previously rubbing over the old rusty disc. Is it wise to have this against a nice new shiney brake disc? Or will it corrode the new disc in some way.
Please, take your car to a professional mechanic2. With regards to my shakey 12 and 6 o'clock wheel, when the car was raised and the wheel went back on, the wheel really could be juddered about 5mm forward or back. And i could see the whole assembly move with it behind the wheel. It's probably not good to be driving like that. And if it is a case of that central nut not going on tight enough, where can I find another nut that fits? It's bigger than any of my socket sizes too, so I wasn't able to see if a wrench could have tightened it better.
Please, take your car to a professional mechanic3. So does my wheel now show NO signs of it being the wheel bearing at fault? There is no noise when going round corners, or travelling at all. And in which case, I spent £26+ vat on a wheel bearing which isn't being used. Should I hang onto it or try and sell it? I doubt anyone with my car will be looking for one who aims to DIY their vehicle.
Please, take your car to a professional mechanicToday -- perhaps I'll assess the state of the other front wheel, and look in particular at the central nut, since that wheel doesn't wobble. If I can remove the nut, and try it on the wobbly wheel, and it fixes the problem, then I can just get a new nut I presume. (but what is the nut?)
See, I didn't realise the nut had to be tapped into a groove to stop it coming out.
From the photo it looks like a staked nut. Once it has been tightened down to the correct torque, punch the rim of the nut slightly into the groove in the stub.
