Firstly thanks for the advice I've robbed from you guys in the past , usually find what I need using the old bit search function but this one has me stumped.
I'm tiling the kitchen above the worktops using brick effect tiles with bevelled edges, which is going fine.
Finally the end is in sight but here is my problem: I have reached the end of the worktop and the black 6mm tile edging is fine for the bevelled edge of the full tile but when I cut the tile in half it comes out higher then the edging (here's a diagram cos my explanation is C**p)
What do the pro's do in this position? Would bigger edging look ok? Or would it look ridiculous?
Arrrrrrrghhhhhh, HELP PLEASE
