Am I right in saying that I need to initially re-render the exposed brick wall and then use the dot & dab method to fix the board to the wall?
Unless you have huge discrepancies in level or holes, it’s a waste of time & money re-rendering before fixing the Aquapanel, the idea is to use the adhesive dabs to make up any discrepancies & level the panels. If your going to re-render you might as well tile straight onto that (tile weight permitting) but you will have to leave it 4 weeks to dry out before tiling unless you use a quickset render (expensive).
I read in another post
//www.diynot.com/forums/viewtopic.php?t=98056 that it's suggested to use Aquapanel for the wet area and use tanked plasterboard for the rest of the bathroom. Is that sensible or should I use Aquapanel for the entire wall?
They also talk about whether or not to tank the Aquapanel in the shower area with
http://www.tilefixdirect.com/product/BAWP1C.html?gclid=CPPD8db-qKsCFYIKfAod6Fpvzg. Is tanking Aquapanel needed?
That’s a very old thread which I haven’t read before.
gcol no longer posts & was the author of the Tiling Sticky, which I hope you’ve read. He was a respected contributor who I knew quiet well but I’m surprised he appears to recommend tanking Aquapanel; not what I would have expected from him
. It’s true that Aquapanel is technically only moisture resistant & will absorb water but it will not disintegrate when wet, unlike plasterboard. As can be seen from other posts on the same thread (& stated by the manufacturer), Aquapanel is considered more than adequate for a domestic shower installation & tanking is not necessary unless you are constructing a wet room; but I wouldn’t use AQP in a wet room anyway, I’d use a fully waterproof backer board to start off with.
Tanking plasterboard in the rest (dry areas) of the bath/shower room is a complete waste of time & money. Tanking is only necessary in wet areas but if you’re going to tank it & for little more cost you might as well use AQP or a fully waterproof backer board in the first place. Plasterboard used in dry areas in a bath/shower room should always be Moisture Resistant, not standard wall board.
I assume you found that thread using the search facility but there are also dozens of others regarding the use of AQP & other cement based backer boards, waterproof tile backer board, plasterboard & tanking; check those out if you need further reassurance. If you feel the need then of course you can tank the lot but you will be wasting your money.
