Broken ear on a back box
7 May 2012
I was looking around my mother's flat and noticed that a double socket is only being held with one screw. The slidy ear (metal back box) has broken off.
Is there a simple solution? My inclination would be something like a self tapping pillar.
I might be shot down by BAS, but I solved this problem by drilling through the back box, masonry drill and plug into the wall and a long no.4 screw straight thro' the fitting. Probably not the ideal way but it does work.
In the past, I have drilled a hole in the back of the box and tapped it, then fitted a long M3.5 screw.
Rotate the back box 90 deg and use the lugs that are currently top and bottom?
:D :D I think the backbox is embeded in the wall, so if he were to take out he might as well replace it.
If it is the lug that moves that has gone missing just pinch one out of a new backbox. if not I drill the back with 3mm drill and tap it out with the 3.5 tapping tool that are only about 5 quid
Thanks for the suggestions. So it looks like an improvisation, rather than a something existing for the purpose.
