I'm surprised that no one wanted to take on the whole job. IS there something that your not telling us????
Thank the lord.How times have changed.
Puzzled?
I'm more puzzled that you risked a two storey extension on as little as 150mm of concrete. Very amateurish.
It is what the text books specified.
It was approved by the Building Control inspectors.
Was it not normal in those days? Is anything more just a waste of concrete?
After 22 years there are no problems.
If the Inspector was happy then presumably you have very good ground for 150mm of concrete.
erm correct me if im wrong here but I always thought the absolute minimum for a concrete footing is 225mm? and am I right in saying you have clay soil too !!!!
I'd never specify 150mm without some reinforcement in it. I'd always say a minimum of half the width of the footing to ensure the load is spread sufficiently.erm correct me if im wrong here but I always thought the absolute minimum for a concrete footing is 225mm? and am I right in saying you have clay soil too !!!!
It depends on whether you are talking about the thickness of the concrete itself, or its depth in the ground. Part A Table 10 sets out the required dimensions of the foundation trench, but for strip foundations, the starting point is a minimum thickness of 150mm.
Although 150mm is the minimum in the book, in practice 225mm has always been regarded as the min.
So for going by the book I get called 'amateurish'.
