No as the 'conservatory' ended up as an extension with a terrace on the roof so needed Regs anyway.FMST - did your client ever push his extension through to council as a conservatory?
The 2010 document supercedes the 2000 one.
//www.diynot.com/forums/audio-visual/multiple-tv-aerial-sockets.325699/#2413968When we bought this house...
...I did fit another mains booster as we frequently got pixillation, which seems to have improved...
jeds";p="2513466 said:Thanks for that Robin. I'll try to remember in future. Whilst you are on, could I point out that pixelation is 'e' with a single 'l'.
noseall";p="2513498 said:Thanks for that Robin. I'll try to remember in future.
I doubt you will have any difficulty in remembering
Thank you....
...we frequently got pixillation, which seems to have improved...
... but then, you haven't seen our pixies !
Because its a conservatory and not a proper extension and the Building Regs say it is exempt. It still must have adequate foundations or its glass must be toughened bellow 800m for example though, rightly or wrongly as the homeowner you are trusted to not build a death trap.Apologies for resurrecting and old thread - got to this thread after some reading and searching... yet am as confused as before.
I've read 3.15 from:
http://www.planningportal.gov.uk/uploads/br/BR_PDF_ADL1B_2010.pdf
and my planned conservatory meets all those requirements; so is "exempt from the energy efficiency requirements".
That said, how does that make the conservatory exempt from building regulations as a whole (beyond the energy efficiency requirements?)
Thanks!
M.
I have however just seen this:.
http://www.communities.gov.uk/documents/planningandbuilding/pdf/1728453.pdf
Section C25 "Building Control Bodies will want to note that the definition of conservatory in terms of percentage translucent material as set out in previous editions of the Approved Documents no longer applies"
But I think it applies only when the conservatory is not exempt from Building regs.
I am confused
