I'm currently having what's marketed as a 'livin' room conservatory by some or 'orangery' style by others built. The difference is rather more brickwork and a lot of plasterboard at the edges of the roof to kid you it's a lantern roof all of which gives it a more solid appearance than the normal conservatory. But it is under 30m2, has the normal conservatory glazed roof (albeit some of it is covered internally by plasterboard), has a separate heating system and the door between existing and new is an external quality door. In my build the entire front is bi folds and one side wall has a large window. The other side wall is unglazed. The glazed area is a bit over 40% if measured on the external face.
The doubt in my mind was the 50% glazing requirement so I talked to my local BCO who brought up the 50% requirement. Of course I mentioned it was no longer specifically mentioned. The advice they gave me in return was 'don't lose any sleep over it' so I haven't. Common sense rules.
They were more concerned that even though exempt I should ensure it had proper foundations.
