Call out to no power to sockets. Found 3036 fuse blown (and by the looks of it, had done several times!).
Voltage operated ELCB in place on a TT system, 5.8ohm Zdb.
Rodent damage in loft, causing earth fault.
The earth fault on the cable would cause around 40amps to flow, damaging the 2.5mm T+E - every so often an L to N fault blowing the fuse with a bang.
Have replaced damaged cable, checked insulation resistance, and have fitted an RCD temporarily while quoting to replace fuseboards initially with a view to a rewire.
Quite shocking - a real fire risk.
