OP,
unfortunately you have fallen into the trap of expecting all products on the market to be capable of use together.
You have almost come to the correct conclusion but stopped just short of it.
The major component in your system is the boiler. The rest of the system needs to operate so that the boiler's demands are met ( however stupid they may seem on the 400 series ).
Its up to the installer to design the system appropriately.
Most of the time your boiler is over powered for your heat loss.
If you must use a smart pump then you need to have a shunt pump circulating through the boiler to keep that happy, a low loss header, and then you can have your smart pump to transfer heat from the LLH to the load ( ideally at a constant pump pressure ). That will all work fine and operate everything correctly!
Just a little bit over the top for a 10 kW house though! And because the boiler is over powered it will be less efficient because there will be too much flow going to the return but thats the result of an over powered boiler.
I am surprised you have not read the two long threads this year about these problems with higher output 400 series boilers. I know that you think you now fully understand all aspects of the heating industry better than those who work in it and that plumbers all all ignorant having left school at 16 with three GCSEs if they were lucky, but experience of system design and operation gained over several years can be very beneficial.
Tony
Tony
