Mysteryman
I quite agree - simple but safe, including equipment protection!
I have actually just 3-4 days ago installed the weather compensation VR430 etc and am full of hope you are right. The 'unload rads' I have are "inside the zones" and rightly or wrongly I worry about boiler flow immediately after zone closure & flame switch off. There are bound to be some very hot, potentially damaging hot spots - indeed it was bangs and explosions at this point that started me focussing on these issues.
My scheme is quite simple and cheap, as suggested by Grundfos. The only flaw is the needless bypassing during ordinary function. My settings as quoted for the flow volume give about 10% bypass of full load flow (worst case scenario I think). Depends a bit exactly where the autoadapt has put itself in its operation region, and relates to the flow resistance of the flow setter and pump output pressure.
In truth the boiler can do brisk shut downs (if starting to cycle on attempted fire up) even with these fancy controls. This is not so bad as the original situation where an old fashioned timer/thermostat programmer could abruptly shut the zone on full power for its "rest period" early in a heating phase algorithm, before it had reached target. I think it was quite a spphisticated Programmer even with limited learning capability nonetheless - Landis & Gyr REV20 some 12 yrs old.
Nobody has commented on my solenoid controlled valve for bypass idea. It would open on closure of all zones, otherwise closed. Good bypass in flame switch off pump overun, no 'condensing wasteful' bypass during zone(s) open. It would have to "activate" quickly to be effective or an ordinary 2 port zone valve might have done.
