Right I've labled the boiler and roomstat cables
View media item 28297
label the cables (though I think if you look closely the room stat cable is already marked) and disconnect everything from the wiring centre
now using D_hailshams link start connecting everything back in a bit at a time
View media item 70
first connect the feed from the spur
the three port valve
the boiler
the pump
and the cylinder stat (red to 6/yellow to 7/black to 8 )
the cylinder stat connections I've given you are going off how its wired now if you take the cover off the stat and tell us the conections this can be confirmed
now connect the red only from the roomstat to terminal 4 and leave the other cores from the roomstat cable in view
now post a picture
did you get hold off a multi meter BTW?
Matt
View media item 70
the boiler
the pump
now post a picture
Matt
