Cable options for PV installation
20 Jun 2010
Hertfordshire
Hi folks,
I'm planning a solar installation where the panels, batteries and inverter will be around 130m from the house.
Looking at the online calculators I'd need 10mm2 armoured buried).
If I switched loads / circuits when inverter is online then this should be OK. If I use a grid-tie inverter then this will not work as the voltage drop would be 10V at 5KW.
Is this the right / only solution or is there a remote sense I should look into?
C
Consider having the inverter at the house where it is easier to get at.
IIRC losses in the cable will be lower too.
