I’m probably missing lots of things, but as I currently see it, there is only one thing which is guaranteed to happen at the moment of loss of the grid supply – namely that the (essentially ‘infinite’) ‘sink capacity' of what the inverters ‘see’ of the grid will drop dramatically. In nearly all situations, the inverter will therefore see a sudden change in the ‘load’ – either a sudden drop (if there were previously a net export of electricity from the affected segment of the network) or a sudden rise (if there were previously a net import of electricity). That sudden change in load (i.e. inverter output current) could be used to sense the loss of the grid supply, hence the need to shutdown.
However, as I’ve said, the one exception arises if, by chance, the total load in the affected network segment is almost exactly the same as the total inverter capacity in the segment at the moment of grid supply loss – in which case I would not expect the inverters to notice any change in loading. Whether it would be considered acceptable to ignore that very unlikely chance happening, I don’t know – but with DNO staff lives at risk, I wouldn’t have thought so – so I doubt that this, alone, could be the means of sensing the need for inverter shutdown.
Kind Regards, John
Kind Regards, John
